Rotate Plane View
Is there a way to select to xz plane view and rotate the view so the z axis is point up? I want to take screen shots to put into a report, but I need my model to be seen as standing up. There should be an easy way to do this, but I have nothing so far. Thanks
3 Replies Last Post 9 févr. 2013, 16:49 UTC+1
Posted: 1 decade ago 9 févr. 2013, 15:49 UTC+1
I'm to missing a +click button, but you have the Definitions View + sub node for direction and view scale you can edit manually, but clear I would like to have a few default views to "click" it would be easier ;)
Try to suggest it to "support"
Hi I'm to missing a +click button, but you have the Definitions View + sub node for direction and view scale you can edit manually, but clear I would like to have a few default views to "click" it would be easier ;) Try to suggest it to "support" -- Good luck Ivar
Posted: 1 decade ago 9 févr. 2013, 16:26 UTC+1
Thank you very much. I am new to Comsol and was unaware that I could create new views under definitions. It would be nice to have easier view options similar to what most CAD programs offer.
Posted: 1 decade ago 9 févr. 2013, 16:49 UTC+1
COMSOl does have a lot of options, and I discover new combinations regularly, so i'ts just to play ;)
Hi COMSOl does have a lot of options, and I discover new combinations regularly, so i'ts just to play ;) -- Good luck Ivar
