Parametric Sweep - Saving Images
Posted 8 déc. 2024, 10:51 UTC−5 Results & Visualization, Studies & Solvers 0 Replies
I am trying to conduct a parametric study of turbulent flows. I want to sweep through a range of inlet velocities. While I have been able to successfully conduct the study and get the results, I am having difficulties saving those images using job configurations.
I have a parametric sweep set up in the study to actually produce the results, and another one set up inside job configurations. The parametric sweep set up inside job configurations saves my images as files. However, it seems that it only reads one set of data from whatever velocity I have selected inside the plot it is trying to save. It doesn't select through all the velocities inside the plot. So, when it produces the image files, it saves the same image under different names. I don't know how to fix this. Any help would be appreciated. Thanks!
Hello Nero Tyagi
