13 févr. 2013, 14:28 UTC+1
as for any other model, you need to start and proceed the same way: geoemtry, materials, physics, BC's then mesh and solve, and final postprocessing.
Now "bounday" setings are required for typically initial and fixed temperatures and sources, but a "volume source" is a domain condition and not really a "Boundary condition"
Note also that, if you are in any other size than MEMS dimensions (<1mm) then micro-second themperature effects are not really frequent and expected, fromm my knowledge (except perhaps if you are dealing with chemistry and rapid chemical reactions)
14 févr. 2013, 04:44 UTC+1
Thank you Sir,
for your reply.
The matter is the volumetric heat generation varies with time...for example( the transient is of 0 to 50e-06 seconds)- at 1.26E-06 seconds, it is 4e12 w/m3 and 50e-06 seconds, it is 1e10 w/m3... and for this I want to check total thermal flux and temperature variation as output.
You are requested to direct me for this and if possible sir, please mention the steps..
I am deeply re grated for your inconvenience.
Mihir
Thank you Sir,
for your reply.
Mihir
14 févr. 2013, 14:57 UTC+1
you need to define your heat shape via an analytical or a combination of step, rectangle or ramp function (Definitions - Functions, then use the correct (t[1/s]) argument when calling your function in the BC or domain variable field, and set up stepping range values such to cover your transitions and it should go.
Last: check your solver "stepping" settings and do NOT use automatic, but try intermediate or strict, check the doc
