Coil group for homogeneized multi-turn coils
Posted 4 févr. 2025, 11:13 UTC+1 Electromagnetics Version 6.2 0 Replies
Hello, I have a 2D axisymmetric model, where different small solenoids (their cross section) should be treated as a single coil (several sub-coils in series). What I understood from the docs is that one should select all of these domains under a Coil node, and check the Coil Group checkbox. Does it work with homogeneized multi-turn coils? For example: I have 2 domains (rectangles) in r-z plane, one is 4x5 mm (representing 4x5 wires of 1 mm diameter, as a homogeneized multi-turn coil), and one is 2x3 mm (representing another coil with 2x3 wires as a homogeneized multi-turn coil). How can I combine these two into a single coil group? Later, I would like to calculate the coupling of this combined coil to some other combined coils. Thank you Daniel
Hello Daniel Barna
