Thermoelectric heat transfer help
Posted 25 févr. 2025, 01:34 UTC−6 Fluid & Heat, Heat Transfer, Studies & Solvers Version 6.1 0 Replies
When I was conducting heat transfer simulation of thermoelectric modules using COMSOL and employed the lumped thermal system thermoelectric module, an error occurred during the calculation: "Undefined value found." - Detailed information: An undefined value was found in the equation residual vector in . There is 1 degree of freedom, and the vector of the variable comp1.lts.term1_p1_P is NaN/Inf. Located at coordinates: (0,0,0), ... There is 1 degree of freedom, and the vector of the variable comp1.lts.term2_p1_P is NaN/Inf. Located at coordinates: (0,0,0), ... What could be the cause of this? I'm seeking help. Thank you all!!
Hello 云鹏 赵
