                                21 févr. 2013, 01:54 UTC−5
if you are stating with COMSOL, I can only recommend to start in 2D, then later move to 3D once your model is running, particularly when mixing several physics. For a cantilever you draw it simply with a rectangle (I suggest to split in two by the middle with a geometry layer setting at half the height to force 2 mes elements per thickness, minimum), then fix one end and run i.e. an eigenfrequency study
                                27 févr. 2013, 00:02 UTC−5
Thank you very much for your valuable help.
uhyadav
uhyadav
                                9 avr. 2013, 02:56 UTC−4
                                                    I have problem with how to analyses the various physics for RF MEMS switch.
uhyadav
uhyadav
                                9 avr. 2013, 14:24 UTC−4
you need to explain a bit more for us out here to understand, have you looked at the different webinars videos on the main COMSOL site ? such as
www.comsol.eu/video/
http://www.comsol.eu/video/
                                16 avr. 2013, 05:58 UTC−4
This my .mpd file using comsol4.1,please help me for adding physics for simulation of this geometry. For this use electrostatics as a physics.
uhyadav
uhyadav
