S11 calculations
Hello, when calculating the S11 of the antenna placed in the chamber using Comsol, is it calculated directly from the port or indirectly through other means?
1 Reply Last Post 6 mars 2025, 11:08 UTC−5
Posted: 2 years ago 6 mars 2025, 11:08 UTC−5
If I understand your question correctly, then the answer is that it is "calculated directly," i.e., making use of the launched wave and the reflected wave, at that port.
