Modifying Selections with Get and Set in LiveLink for Matlab
Hello everyone,
I could retrieve information of selections with the "get" command (see following example with the model in the attachment).
model1=mphload('SupportSelectionExample1') model1 = COMSOL Model Object Name: SupportSelectionExample1.mph Tag: Model Identifier: root
model1.component.get('comp1').selection('sel16') ans = Geometry geom1: Dimension 3: Domains 4–5 Type: Explicit Tag: sel16 Operation: Explicit
However, I haven't been able to modify the setting under "Geometry" with LiveLink for Matlab. Could anybody help?
Best regards, Anton
1 Reply Last Post 19 mars 2025, 10:52 UTC−4
Posted: 12 months ago 19 mars 2025, 10:52 UTC−4
I found the solution by myself and place it here for anybody who needed it:
Load model:
Set selections with domain numbers:
model1.component.get('comp1').selection('sel21').set([8 14 15 17 19 22 23 24]) ans = Geometry geom1: Dimension 3: Domains 8, 14–15, 17, 19, 22–24 Type: Explicit Tag: sel21 Operation: Explicit
model1.component.get('comp1').selection('sel16').set([4 5 6 7]) ans = Geometry geom1: Dimension 3: Domains 4–7 Type: Explicit Tag: sel16 Operation: Explicit
Save under new name:
mphsave(model1,'SupportSelectionExample1set')
I found the solution by myself and place it here for anybody who needed it: Load model: >>model1=mphload('SupportSelectionExample1') model1 = COMSOL Model Object Name: SupportSelectionExample1.mph Tag: Model Identifier: root Set selections with domain numbers: >> model1.component.get('comp1').selection('sel21').set([8 14 15 17 19 22 23 24]) ans = Geometry geom1: Dimension 3: Domains 8, 14–15, 17, 19, 22–24 Type: Explicit Tag: sel21 Operation: Explicit >> model1.component.get('comp1').selection('sel16').set([4 5 6 7]) ans = Geometry geom1: Dimension 3: Domains 4–7 Type: Explicit Tag: sel16 Operation: Explicit Save under new name: >> mphsave(model1,'SupportSelectionExample1set')
