Discussion on the Validity of Radiation Heat Transfer Modeling Under Cloudy and Clear-Sky Conditions
Posted 20 mars 2025, 04:15 UTC−5 Heat Transfer 1 Reply
Hello everyone,
I am using COMSOL to simulate radiative heat transfer and analyze the radiative performance of a sample under both cloudy and clear-sky conditions. I have obtained surface irradiance data for both cases and am conducting simulations using surface-to-surface radiation heat transfer to evaluate the effects of different atmospheric conditions.
In my model, I consider radiative counterpart temperature and external radiation source irradiance as the primary variables:
For clear-sky conditions: The radiative counterpart temperature is set to outer space at 3K. The external radiation source irradiance is taken from clear-sky surface irradiance data. For cloudy conditions: The radiative counterpart temperature is set to the cloud layer temperature. The external radiation source irradiance is taken from cloudy-sky surface irradiance data.
I have the following questions and would appreciate any insights:
- Are there similar application cases that I can refer to? If so, is my modeling setup reasonable?
- Since the surface irradiance already accounts for atmospheric absorption and scattering, is it appropriate to use surface-to-surface radiation heat transfer (which neglects the effects of the medium) for this simulation?
- In my model, I only vary the radiative counterpart temperature and assume both the cloud layer and outer space are at an infinite distance. However, clouds are much closer to the Earth's surface than outer space. Is this assumption valid, or should I consider the finite distance of the cloud layer in my model?
Thank you for your time—I look forward to your suggestions!
