An Additional Matrix "Constraint Jacobian" In Shell Module
Recently, when I checked the process of "Elimination Constraint Handing" in Shell Module, I found something confused.
As a toy model, I just built a plate in the Shell Module and no boundary conditions are applied. However, in the matrix "Constraint Jacobian", an additional constraint was used, i.e. . What's the meaning for this constraint?
In my knowledge, it implies the displacement component u_3 should be equal to 0 for all nodes. Actually, the surface plot in "Results" tells me this is misunderstanding.
Any guidance would be very appreciated. Thanks!
1 Reply Last Post 23 avr. 2025, 14:05 UTC−4
Posted: 2 years ago 23 avr. 2025, 14:05 UTC−4
Sorry , I think I find it, the constraint means instead. That implies the displacement of shell normal should be 0 as Reissner-Mindlin assumption required. Thanks.
Sorry , I think I find it, the constraint means n_3 \cod \theta_3=0 instead. That implies the displacement of shell normal \theta_3 should be 0 as Reissner-Mindlin assumption required. Thanks.
