Failed to evaluate negative error for Heat Transfer in Porous Media
HI, I am trying to simulate a flow through packed bed and transfer between the fluid and porous bed using thermal non equilibrium case, but I am getting this error it is because of the model input in the Fluid section, when I enter a number then the error is not coming, but when I set the default ht/porous/fluid/T value then it is giving error, i have coupled the Brinkmans equation with the HTPM using Non Isothermal Flow Multiphysics
0 Replies Last Post 9 juil. 2025, 22:17 UTC−4
Hello Swami Sonawane
