How to combine the Frequency Domain and Coil Current Calculation
Posted 15 mars 2013, 11:33 UTC−4 Low-Frequency Electromagnetics, Studies & Solvers Version 4.3a 0 Replies
i´m trying to simulate an numerical coil with alternating current. The coil is built with the "Multi-Turn Coil Domain". My coil type is numeric wich requires an additional "Coil Current Calculation" step before my "Frequency Domain" step in my study. I solved it for 50,500,5000 Hz and looked at the coil paramters. My coil excitation is set to 0.15A wich should be the coil current for all frequencies. The "Coil voltage" and "Coil resistance" should be different for each frequency which is not, if i do a global evaluation for those two parameters.
Anyone got an idea how i can solve my problem? I´m attaching my modelfile, if someone is willing to take a look at it.
Best wishes,
Andreas Schneider
Hello Andreas Schneider
