PCM simulation setup in COMSOL Multiphysics.
How to do PCM simulation setup in COMSOL Multiphysics. https://drive.google.com/file/d/1QJDjC4hOGsd8K3qDd_vl-luYoqq_sv8j/view?usp=drive_link
My study is cooling of battery cell by using both PCM and air.The cell is covered with cylinder PCM and again it is covered with aluminium casing cylinder.The aluminum casing is cooled by blowing air at some velocities. Here heat transfer takes place from cell to PCM,PCM to alumnium casing and alumiumuin casing to air.I have doubt about PCM simulation setup. Since when PCM melts its density changes and also other property changes with temperature. How to setup the simulation in COMSOL for a natural convection of PCM. when PCM melts, it converts solid into liquid.How to set physics for above problem.
0 Replies Last Post 15 juil. 2025, 01:25 UTC−4
Hello Ravikumar Talapati
