Transmission between the gratings
Posted 19 mars 2013, 05:18 UTC−4 Structural Mechanics Version 3.5a 0 Replies
I try the same way like calculating the transmission between different liquids, and the result is correct. But, when I use the same way to calcuate the transmission through the grating from the water, i find transmission pluses reflection ratio does not equal1. By the way, i have attached the mode for your preference. Thanks very much.
Hello Pengjiang Wei
