How to add new material properties to a material?
Posted 22 mars 2013, 04:30 UTC−4 Materials, Parameters, Variables, & Functions Version 4.3a 0 Replies
Suppose I need to make calculations on electrooptics. Then I need to make my materials have Electrooptic tensor output property. If I go to "Materials"->"Material x"->"User-defined property group" I find only fixed variety of Output Properties available. As I see the Local properties box doesn't do the thing as it is visible only inside the material.
Is there a way to add my new desired parameter to the Output Properties of material?
By the way is it also possible to add fields to Model Inputs list of the material? It is not yet needed, but still I probably could invent a situation, when it would. For strictness, at least.
Glad to get any help.
Hello Nikita Kondratiev
