solver issue
for PCM +Air hybrid cooling of battery pack, i enabled conjugate heat transfer module where turbulence physics defined for Air domain and under Heat Transfer in solids and fluids battery defined as solid and pcm as a fluid..selected phase change material under PCM(not sure about PCM setup as i asked earlier doubt.) we are getting results only for the stationary study and getting error for time dependent study.
but we require time dependent simulations only...kindly give idea
0 Replies Last Post 15 juil. 2025, 06:59 UTC−5
Hello Ravikumar Talapati
