thermal BC's across the interanl surface between the heat sink and air in the channel
Posted 30 mars 2013, 12:50 UTC−4 Heat Transfer & Phase Change Version 4.3 1 Reply
n Model Library : Heat transfer module : Tutorial models: heat sink .
It is considered the temperature filed is continuous across the internal surface between the heat sink and the air channel. first of all :
what about heat flux ? It is considered continuous too or not ? if it is not, What kind of thermal BC's across the internal surface between heat sink and air channel ? Please can you state your answer in equations?
thanks
Ahmed ... Udmercy
thanks
Ahmed ... Udmercy
1 Reply Last Post 3 avr. 2013, 16:51 UTC−4
