Split solid into two domains
I have a 3D model that I've imported into COMSOL. In Solidworks, I have two features that are separate, however, when imported into COMSOL, they become a single domain and a single geometry feature.
Using the Split Geometry tool failed to split the solid into two domains. I was looking but didn't see a way to split the domain a a particular boundary. Can this be done?
Looking around forums online, I found a suggestion for splitting a domain suggesting to "extrude a line from the work plane - do not use a 3D block."
This sound like it's possible, however, the boundary where I would like to split the domain is curved so this doesn't sound easy.
Any help would be greatly appreciated and if someone in the forum feels inclined, I'll post the model file to work from.
Art
1 Reply Last Post 1 avr. 2013, 22:14 UTC+2
Posted: 1 decade ago 1 avr. 2013, 22:14 UTC+2
I'm not sure what you name a "feature", in Solidworks (latest versions) you can generate one or several "bodies" in a "part" (=file) and assemble "part"s in an "assembly" (= file with links to part files).
COMSOL will read in the SolidWorks bodies as well as the parts as separate volumic objects, and then analyse these to generate DFEM Entities => Domains and Boundaries depending on how these bodies and/or part(s) interact (having common boundaries (=surface segments) or not)
It's often easier to "split" the part in Solidworks, also to "split-line" surfaces to make specific subdomains easier to select, even if this sometimes is also easy to do in COMSOL (but not always, for complex geometries)
Hi I'm not sure what you name a "feature", in Solidworks (latest versions) you can generate one or several "bodies" in a "part" (=file) and assemble "part"s in an "assembly" (= file with links to part files). COMSOL will read in the SolidWorks bodies as well as the parts as separate volumic objects, and then analyse these to generate DFEM Entities => Domains and Boundaries depending on how these bodies and/or part(s) interact (having common boundaries (=surface segments) or not) It's often easier to "split" the part in Solidworks, also to "split-line" surfaces to make specific subdomains easier to select, even if this sometimes is also easy to do in COMSOL (but not always, for complex geometries) -- Good luck Ivar
