Edgar J. Kaiser
Certified Consultant
4 avr. 2013, 12:05 UTC+2
Diana,
port boundaries must bei PEC or impedance boundary conditions. That is what I stumbled across when I tried it the first time.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Diana,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
16 avr. 2013, 18:20 UTC+2
thank you for your reply. However, I am still confused since also the impedance boundary condition does not take my boundary choice. Maybe there is something altogether wrong with my model of the cross section, could someone take a look? I simply want to include a RF excitation (travelling into the plane of my model) to the center conductor and see the field distribution.
Edgar J. Kaiser
16 avr. 2013, 18:56 UTC+2
Diana,
I indeed think that the model is not appropriate. My comments:
1. The metallization is modelled infinitely thin. This results in singularities
2. In planar symmetry you can't send a wave into the plane. If you connect a lumped port it would be connected all along the plane's normal direction. This is probably not what you want.
I put a lumped port into your model to show in principle how a lumped port is to be defined. The lumped port always connects two PEC or impedance boundaries. However for the above mentioned reasons this will still not do what you want.
I think you must go to 3D and model the conductor with finite dimensions, not just as boundaries.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Diana,
Cheers
Edgar
Edgar J. Kaiser
22 avr. 2013, 12:46 UTC+2
how to design input and output coplanar waveguide so they can be coupled .
