23 avr. 2013, 11:20 UTC+2
First of all you should use MF and not MEF for a simple B field from a current (MEF is far more complex and solves for the voltage)
Then also very important the B field is looping around in the "air or vacuum surrounding the wire, but you have not defined any volume with any mesh all around the wire.
Check the model library, you MUST use an air or vacuum region (block or large cylinder all around the wire so that the B field can develop in the numerical solution proposed
You example is far simpler to start with in 2D, just draw two circles, one for the wire and one much larger for the air, once you master the 2D you can try a 3D model
23 avr. 2013, 11:28 UTC+2
thank you ivar it's clear ;))))
23 avr. 2013, 12:22 UTC+2
Hi ivar,
I think that's ok now what do you think....the model is attached
Cheers
Hi ivar,
Cheers
23 avr. 2013, 13:05 UTC+2
That's much better ;)
but what you notice now is that with your sharp edges, you have singularities along the edges. For that its better to draw the section, fillet the corners, and extrude along the length
23 avr. 2013, 13:37 UTC+2
Ok thank you ivar ;)))
30 avr. 2013, 12:30 UTC+2
Hi ivar,
now i simulate a 4 straight have the same length to find the magnetic field for the 3 component i found a result but i'm worry about the result because i'm not sure for the density of current..... actually i want a 1mA value of current but i'm not sure how i can define the density to get this value of current, i now I=j*dS but i define it at z component only or also for the 3 component,
(the file is attached) thank you for ur help.
Hi ivar,
30 avr. 2013, 13:42 UTC+2
Hi ivar,
now i simulate a 4 straight have the same length to find the magnetic field for the 3 component i found a result but i'm worry because i'm not sure for the density of current..... actually i want a 1mA value of current but i'm not sure how i can define the density to get this value of current, i know I=j*dS but i define it at z component only.
Hi ivar,
