About the ploting the results
Hey Ivar,
I just bulit a simple model to analyze the heat transfer. After analysis is finished, I want to plot the result. So I cut one point 2D-1, but I can not plot the temperiture variation with time. Could you tell me how to deal with it?
BEST,
Bond
2 Replies Last Post 25 avr. 2013, 08:33 UTC+2
Posted: 1 decade ago 24 avr. 2013, 11:41 UTC+2
if you do a time series, the default 1D plot is w.r.t. time. Now if you define a point by a Data set cut point "DataSet" then you can plot i directly, or you might use the DErived values to write out some equations and plot the resulting table data (that by default is in time for a time series solver case
Hi if you do a time series, the default 1D plot is w.r.t. time. Now if you define a point by a Data set cut point "DataSet" then you can plot i directly, or you might use the DErived values to write out some equations and plot the resulting table data (that by default is in time for a time series solver case -- Good luck Ivar
Posted: 1 decade ago 25 avr. 2013, 08:33 UTC+2
got it. thanks a lot!
