Edgar J. Kaiser
Certified Consultant
1 year ago
1 oct. 2025, 15:01 UTC−4
Margarida,
a cut line dataset and a line plot using it is what you want.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Margarida,
Cheers
Edgar
1 year ago
6 oct. 2025, 12:32 UTC−4
Thank you, Edgar.
A cut line 2D or 3D? I tried to use a cut line 3D but using 2 points but I couldn't figure out right z-coordinate of those two points (my thin layer is in the plane xy).
Thank you, Edgar.
Edgar J. Kaiser
1 year ago
7 oct. 2025, 02:21 UTC−4
Updated:
1 year ago
7 oct. 2025, 05:39 UTC−4
If the layer is in the xy plane, then z should be 0?
If the thin layer is implemented as a boundary you may see a temperature discontinuity. In this case you can use the up() and down() operators to see the temperatures on each side of the boundary.
Edgar J. Kaiser
www.emphys.com
1 year ago
7 oct. 2025, 10:01 UTC−4
The layer is a xy plane at a particular z=z0. The layer has thickness but there is no z-coordinate associated with it since it was defined as layered material.
If I use the cut line 3D, I can choose the layered material that I previously selected as one dataset, I choose the x and y coordinates accordingly to the line I want but I could not find the right z to use. I tried the z0, zero (as you suggested ) and other options but I could not find the right z choice.
Have you got other suggestions?
Thank you.
Thank you.
Robert Koslover
Antennas, Waveguides, Electromagnetics
1 year ago
9 oct. 2025, 10:08 UTC−4
I suggest that you post your .mph file to the forum.
