Simulation Times Increasing with LiveLink for MATLAB
I've been running automated simulations with LiveLink for MATLAB, where each run makes small geometry changes, remeshes, and solves. I’ve noticed that while early simulations take ~45 minutes, after 20–30 runs, the simulation time increases a lot (more than twice), even though the problem size stays the same.
Has anyone else experienced this slowdown?
Are there best practices for preventing resource issues or memory leaks when using LiveLink for MATLAB for multiple runs? Is it helpful to restart the COMSOL server periodically, and if so, how do you safely restart it without physically clicking from the start menu?
Would appreciate any advice!
3 Replies Last Post 5 déc. 2025, 04:49 UTC−5
Posted: 12 months ago 14 nov. 2025, 04:29 UTC−5
Hi Aragon
This shouldn't happen. What version of Comsol are you using?
Can you share the code? Either here or by sending it to support?
Restarting is possible, but shouldn't really be necessary. The commands mphstartcomsolmphserver and mphstart can be used for this.
Lars Gregersen
Comsol Denmark
Hi Aragon This shouldn't happen. What version of Comsol are you using? Can you share the code? Either here or by sending it to support? Restarting is possible, but shouldn't really be necessary. The commands mphstartcomsolmphserver and mphstart can be used for this.
Posted: 12 months ago 14 nov. 2025, 19:01 UTC−5
Hi Aragon
Hi Lars, thank you for your response. I am using COMSOL 6.3.
I'm attaching the relevant code snippets I use for looping through my simulations. I am afraid it might be difficult to replicate the issue directly, since my workflow involves opening a large .mph file and editing it, unfortunately, the file is too massive to share. However, this code should be pretty self explanatory and does cover the entire process.
If you spot anything in the code that might be causing problems, I’d appreciate your insights.
As for starting the server: I launch COMSOL + MATLAB from the Windows Start menu, then run my Base.m script from the MATLAB GUI. I haven’t used mphstart in this code, but when I tried adding it previously in the IterPartitionandSolve.m, I received an error indicating that the server was already running. So, there should be another way to close it and reopen it, if I understood it correctly.
Let me know if there’s anything in the code that stands out, or if you have any suggestions based on this setup. Thank you!
>Hi Aragon > >This shouldn't happen. What version of Comsol are you using? > >Can you share the code? Either here or by sending it to support? > >Restarting is possible, but shouldn't really be necessary. The commands mphstartcomsolmphserver and mphstart can be used for this. Hi Lars, thank you for your response. I am using COMSOL 6.3. I'm attaching the relevant code snippets I use for looping through my simulations. I am afraid it might be difficult to replicate the issue directly, since my workflow involves opening a large .mph file and editing it, unfortunately, the file is too massive to share. However, this code should be pretty self explanatory and does cover the entire process. If you spot anything in the code that might be causing problems, I’d appreciate your insights. As for starting the server: I launch COMSOL + MATLAB from the Windows Start menu, then run my Base.m script from the MATLAB GUI. I haven’t used mphstart in this code, but when I tried adding it previously in the IterPartitionandSolve.m, I received an error indicating that the server was already running. So, there should be another way to close it and reopen it, if I understood it correctly. Let me know if there’s anything in the code that stands out, or if you have any suggestions based on this setup. Thank you!
Posted: 11 months ago 5 déc. 2025, 04:49 UTC−5
We have had a few reports of solution increasing while solving the same problem repeatedly in Comsol 6.3.
Upgrading to Comsol 6.4 solves these problems. If the problem persists for your models then please report such cases in the Forum or by sending a report to our support.
Lars Gregersen
Comsol Denmark
We have had a few reports of solution increasing while solving the same problem repeatedly in Comsol 6.3. Upgrading to Comsol 6.4 solves these problems. If the problem persists for your models then please report such cases in the Forum or by sending a report to our support.
