Far‑field radiation from magnetoelectric antenna driven by piezoelectric–piezomagnetic coupling (no electrical port)
Posted 6 janv. 2026, 08:32 UTC−5 Physics Interfaces 2 Replies
Hello everyone, I am working on a magnetoelectric (ME) antenna model in COMSOL Multiphysics and I would appreciate guidance on the correct strategy to compute the far‑field radiation. Model description The antenna is composed of: grounded Mo bottom electrode, piezoelectric AlN layer, magnetostrictive FeGaB layer The surrounding medium is a spherical air domain (inner sphere, and outer pml sphere) The physics interfaces used in the near‑field study are:Electrostatics (ES), Solid Mechanics (SM), Magnetic Fields (MF) with the following multiphysics couplings:Piezoelectricity (ES ↔ SM), Piezomagnetism / magnetostriction (SM ↔ MF) The system is solved in the frequency domain. A harmonic voltage is applied across the piezoelectric layer, generating strain that propagates into the magnetostrictive layer and produces a time‑varying magnetization. An external bias magnetic field is also applied in the air domain. Importantly, this antenna is not electrically fed (no lumped port, wave port, or impressed current), as the source of radiation here is the antenna due to the magentization evolution in FeGaB. My Question: I would like to compute the far‑field radiation pattern of this antenna. I added the Electromagnetic Waves, Frequency Domain (EMW) interface and tried to use COMSOL’s near‑to‑far‑field transformation, but all far‑field quantities (e.g. emw.normEfar) evaluate to zero. I understand that: 1. Far‑field calculations in EMW require a non‑zero electromagnetic near field (E, H) 2. EMW does not directly couple to Magnetic Fields, Solid Mechanics, or Electrostatics 3. Variables such as mf.Mx, mf.Hx, or es.V are not accessible inside EMW as sources I attempted to introduce equivalent magnetic or electric current sources based on the magnetization, but EMW does not recognize variables from the MF interface, even when defined through component variables.
Questions 1. What is the recommended COMSOL workflow to compute far‑field radiation from a mechanically driven magnetoelectric antenna that has no electrical port? 2. Is the correct approach to: Perform a first study to compute the magnetization, then use a second EMW‑only study with an equivalent current (calculate it in matlab based on the output magnetization or field that i wil get due to the near field study)? 3. Are there any built‑in features or best practices in COMSOL for handling radiation from magnetization‑driven sources (e.g., magnetic dipole–type antennas)?
Any guidance, references, or example models would be greatly appreciated. Best regards, Rayan
