Fluid flow with a moving solid object/hole
I would like to model the airflow in a room occupied with people, and to allow the people (cylinders) to move around in the room. Is this possible in COMSOL?
For a silly example in 2D: I have a rectangular domain with a circle inside. Two opposing sides of the rectangle are defined as inflow and outflow for a turbulent flow physics respectively. How can I make the circle change position inside the rectangle as a function of time?
Any help much appreciated!
/Daniel
2 Replies Last Post 4 juin 2013, 14:03 UTC+2
Posted: 1 decade ago 30 mai 2013, 17:06 UTC+2
Hi Daniel,
Take a look at this example, that may help you to solve your problem.
Good luck,
Paul
Hi Daniel, Take a look at this example, that may help you to solve your problem. Good luck, Paul
Posted: 1 decade ago 4 juin 2013, 14:03 UTC+2
Dear Jean-Paul,
I wolud like to have a look to your simulation "ACO 2xMOV OBJ 1xSliding along W Auto-Remesh 2013-05-30NS" but I can´t open it, because I don´t have the "pressure acoustics, Transient (actd) module " license. Could you explain me how to put the object moving?
Best regard,
Diana Fidalgo
Dear Jean-Paul, I wolud like to have a look to your simulation "ACO 2xMOV OBJ 1xSliding along W Auto-Remesh 2013-05-30NS" but I can´t open it, because I don´t have the "pressure acoustics, Transient (actd) module " license. Could you explain me how to put the object moving? Best regard, Diana Fidalgo
