Improve the calculation speed
How to improve the calculation speed (convergence is very slow) for complex electromagnetic field models in COMSOL?
1 Reply Last Post 31 janv. 2026, 09:55 UTC−5
Posted: 6 months ago 31 janv. 2026, 09:55 UTC−5
Updated: 6 months ago 31 janv. 2026, 09:57 UTC−5
Some of the concepts that apply to handling very large models also apply to speed: See https://www.comsol.com/support/knowledgebase/1030
There are also many helpful changes you can make by adjusting your geometry, mesh, element discretization, and solver settings. Experiment with them! Use symmetry when possible, to create half-size or quarter-size (or leverage other symmetries) models. Simplify your geometries and meshes. Learn about the different solvers and their settings and how these trade-off in terms of the memory required, the speed, the stability, and the accuracy.
If you provide more details about your problem or post your .mph file to the forum, you may be able to get a more specific suggestion.
*Some* of the concepts that apply to handling very large models also apply to speed: See https://www.comsol.com/support/knowledgebase/1030 There are also *many* helpful changes you can make by adjusting your geometry, mesh, element discretization, and solver settings. Experiment with them! Use symmetry when possible, to create half-size or quarter-size (or leverage other symmetries) models. Simplify your geometries and meshes. Learn about the different solvers and their settings and how these trade-off in terms of the memory required, the speed, the stability, and the accuracy. If you provide more details about your problem or post your .mph file to the forum, you may be able to get a more specific suggestion.
Reply
