point load at arbitrary points
Yuvashree Mani Urmila
I am working on a cylindrical model. I need to apply load at points.Not the predetermined points but other points too.suggestions please
1 Reply Last Post 16 mai 2013, 17:53 UTC+2
Josh Thomas Certified Consultant
Posted: 1 decade ago 16 mai 2013, 17:53 UTC+2
Yuvashree,
If the point locations aren't predetermined, how/when are they determined?
If you know the point locations before solving, you can just create points in the geometry that will then be available for selection when applying the point loads under the physics section.
Josh Thomas
AltaSim Technologies
Yuvashree, If the point locations aren't predetermined, how/when are they determined? If you know the point locations before solving, you can just create points in the geometry that will then be available for selection when applying the point loads under the physics section. Best regards, Josh Thomas AltaSim Technologies
