component variables and global parameters for this .mph file
I have access to v6.2, and this simuulation is uploaded to the COMSOL application gallery only as 6.4. I can still use the .txt file containing all of the formatted equations for rpi model phase change at the wall and in the 3d space as well as corresponding heat transfer equations. The phase change is modeled in the formatted equations that are defined in the parameters and in the variables.
Can someone using v6.4 send a .txt export of all of the parameters and variables?
This is the simulation i am referencing from the application gallery: https://www.comsol.com/model/subcooled-nucleate-boiling-with-extended-rpi-model-113081
2 Replies Last Post 7 avr. 2026, 16:18 UTC−4
Posted: 8 months ago 3 avr. 2026, 05:11 UTC−4
Updated: 8 months ago 3 avr. 2026, 05:12 UTC−4
Here you go
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Here you go
Posted: 8 months ago 7 avr. 2026, 16:18 UTC−4
Here you go
Thank you very much!
>Here you go Thank you very much!
