Unable to read or write out-of-core file
I have received the error:
" - Feature: Eigenvalue Solver 1 (sol1/e1) Unable to read or write out-of-core file."
Any idea what this means? I have TBs of disk space so I don't think that should be a problem.
4 Replies Last Post 24 sept. 2026, 04:17 UTC−4
Robert Koslover RF/Antennas
Posted: 4 weeks ago 22 sept. 2026, 15:34 UTC−4
If you haven't already, go to menu items File > Preferences > Files and check your settings there.
Robert A. Koslover
Posted: 4 weeks ago 23 sept. 2026, 10:13 UTC−4
The file preferences are standard. Nothing amiss that I can see.
Posted: 4 weeks ago 23 sept. 2026, 17:01 UTC−4
Updated: 4 weeks ago 23 sept. 2026, 17:04 UTC−4
Another quick test that you might want to try would be to create a computationally smaller model and see if it does the same thing. Have you ever created any similar models for which you succeeded in using an out-of-core file? Note that most of the time, out-of-core usage (when successful) leads to much slower execution than fully in-RAM calculations. Also, how much RAM do you have? How much is being used? Are you working on a stand-alone or networked computer? Are you able to estimate how many bytes it is attempting to save/swap to/from out-of-core storage? If you are using a Windows-based computer, take a look at the memory usage(s) during execution using the Task Manager. And what does the Comsol log say is the Degrees of Freedom for this model? It also may be helpful to anyone thinking about this if you can post your .mph file to the forum.
Robert A. Koslover
Another quick test that you might want to try would be to create a computationally smaller model and see if it does the same thing. Have you ever created any similar models for which you succeeded in using an out-of-core file? Note that most of the time, out-of-core usage (when successful) leads to *much* slower execution than fully in-RAM calculations. Also, how much RAM do you have? How much is being used? Are you working on a stand-alone or networked computer? Are you able to estimate how many bytes it is attempting to save/swap to/from out-of-core storage? If you are using a Windows-based computer, take a look at the memory usage(s) during execution using the Task Manager. And what does the Comsol log say is the Degrees of Freedom for this model? It also may be helpful to anyone thinking about this if you can post your .mph file to the forum.
Posted: 4 weeks ago 24 sept. 2026, 04:17 UTC−4
Updated: 4 weeks ago 24 sept. 2026, 05:26 UTC−4
I think this is rather a support case than a case for the forum.
And as Robert mentioned, if the solver needs to switch to out-of-core storage you are in troubles anyway.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
I think this is rather a support case than a case for the forum. And as Robert mentioned, if the solver needs to switch to out-of-core storage you are in troubles anyway.
Reply
