Problem with heat transfert in lava
Hello everyone,
I posted a topic here because I encounter a problem with Comsol. Indeed, I try to modelize a lava flow, but I have a problem to fix the temperature of middle flow as you can see on this picture below (:
www.pixenli.com/images/1370/1370356942039372700.png (:
I would like to fix a line of same temperature in the aim to get two gradients : between the floor and the middle of the flow and between the surface and middle of the flow (:
Thank you in advance (:
Alexis, Jordan.
P.S : Sorry my bad english, I'm french >.<
3 Replies Last Post 11 juin 2013, 13:31 UTC+2
Posted: 1 decade ago 6 juin 2013, 12:11 UTC+2
Up !
Comsol, c'est pire qu'une femme
Up ! -- Comsol, c'est pire qu'une femme
Posted: 1 decade ago 11 juin 2013, 10:17 UTC+2
Up !
Posted: 1 decade ago 11 juin 2013, 13:31 UTC+2
Hi Jordan,
I think I don't understand your problem, you want to imposed a Dirichlet boundary condition of constant temperature inside your domain (in a line) ?
- Is this lava flow or liquid glass you are simulating?
- I think you cannot imposed boundary condition inside the domain. You can make a source term in that line and make a damping function which is zero if T=T_const, positive if T< T_const and negative if T>T_const.
Kind regards,
Duarte Albuquerque
Hi Jordan, I think I don't understand your problem, you want to imposed a Dirichlet boundary condition of constant temperature inside your domain (in a line) ? - Is this lava flow or liquid glass you are simulating? - I think you cannot imposed boundary condition inside the domain. You can make a source term in that line and make a damping function which is zero if T=T_const, positive if T< T_const and negative if T>T_const. Kind regards, Duarte Albuquerque
