time information of streamline
I solved a laminar flow diffusion mixing stationary problem for a simple system.
In the result I plot 1000 streamlines. I need to know the mixing time for every streamline so I have to get the time information of streamlines. i.e: I need to know how much time does it take for the liquid to go from one point on a streamline to the other point.
Is it possible?
Or I can read out a table of x,y,z coordinates and time as well as other physical information in each streamline to a text file then process it with matlab. Is there a way to do so?
Thank you.
4 Replies Last Post 2 juil. 2013, 10:55 UTC+2
Posted: 1 decade ago 1 juil. 2013, 22:37 UTC+2
Anyone has an idea how to do this? I just need a way to calculate the time for liquid to travel between one point to another point along a streamline.
Posted: 1 decade ago 1 juil. 2013, 23:22 UTC+2
Dingjie,
maybe this thread www.comsol.com/community/forums/general/thread/35623 can give you a hint how to export streamline coordinates.
But as you stated you ran a stationary study so it doesn't contain time. You might consider integrating something like the quotient dr / v(r) along the streamline. r being the spatial position and v(r) the velocity along the streamline. This should give you the time, right?
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Dingjie, maybe this thread http://www.comsol.com/community/forums/general/thread/35623 can give you a hint how to export streamline coordinates. But as you stated you ran a stationary study so it doesn't contain time. You might consider integrating something like the quotient dr / v(r) along the streamline. r being the spatial position and v(r) the velocity along the streamline. This should give you the time, right? Cheers Edgar -- Edgar J. Kaiser http://www.emphys.com
Posted: 1 decade ago 2 juil. 2013, 00:06 UTC+2
Thank you for your reply. That is the same thing in my mind.
Is there a way to export a data file that contains the coordinates of streamlines along with some values at the coordinate, i.e. velocity vector, velocity magnitude and concentration? In my streamline out put file, there is only coordinates and I have to scan through the 2D velocity map and concentration map to get the info, which is a time consuming process.
Thank you for your reply. That is the same thing in my mind. Is there a way to export a data file that contains the coordinates of streamlines along with some values at the coordinate, i.e. velocity vector, velocity magnitude and concentration? In my streamline out put file, there is only coordinates and I have to scan through the 2D velocity map and concentration map to get the info, which is a time consuming process.
Posted: 1 decade ago 2 juil. 2013, 10:55 UTC+2
Sorry I don't know, I don't have the flow module.
Edgar J. Kaiser
www.emphys.com
Sorry I don't know, I don't have the flow module. -- Edgar J. Kaiser http://www.emphys.com
