why COMSOL is solving so slowly
Hi All,
I am running a case with radiation heat transfer. The 3D geometry is quite simple. Number of degrees of freedom solved for: 56826 (plus 39748 internal DOFs), and element number is around 24K. I use the segragated solver.
And I found that: the time for assembly in each step is around 15 minutes, and memory usage seems OK, around 8GB.
I wonder whether this calculation speed is normal or not.
Thanks.
5 Replies Last Post 6 sept. 2013, 08:54 UTC+2
Posted: 1 decade ago 3 sept. 2013, 07:50 UTC+2
It does not sound normal, neither the use of 8GB of memory. Are you solving a steady-state or a time-dependent problem?
Posted: 1 decade ago 4 sept. 2013, 04:22 UTC+2
Hi Lasse, it is a steady-state case.
Posted: 1 decade ago 4 sept. 2013, 09:03 UTC+2
What kind of hardware you have?
[QUOTE] Hi Lasse, it is a steady-state case. [/QUOTE] What kind of hardware you have?
Posted: 1 decade ago 6 sept. 2013, 05:31 UTC+2
I am using a Dell workstation with 48GB memory.
Posted: 1 decade ago 6 sept. 2013, 08:54 UTC+2
OK, you must have a problem in the model, I presume. I am not working myself on this topic, but try to find out a same kind model, and solve that for comparison.
[QUOTE] I am using a Dell workstation with 48GB memory. [/QUOTE] OK, you must have a problem in the model, I presume. I am not working myself on this topic, but try to find out a same kind model, and solve that for comparison.
