Calculating the power-flow across several parallel planes
Posted 3 oct. 2013, 05:57 UTC−4 RF & Microwave Engineering, Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization Version 4.3, Version 4.3a 0 Replies
Is there an efficient way to calculate the power-flow across several parallel planes? I tried to use the "Cut Plane" option under Results->Data sets. There I can create the parallel planes, but if I then use Results->Derived Values -> Surface Integration I only got the sum of the integrals over all plans. But I'm looking for the individual integrals over each plan.
Thanks a lot in advance
Hello Felix
