Cross section simulation -results visualization
Zelenyak Andreea Manuela Certified Consultant
Hi all,
does any one know how can I plot the results from a Cross section simulation into 3D Plot Group. So what I want is to see the 2D results into 3D geometry frame. It is possible?
Thank you very much
1 Reply Last Post 23 oct. 2013, 11:34 UTC+2
Bettina Schieche COMSOL Employee
Posted: 1 decade ago 23 oct. 2013, 11:34 UTC+2
one idea could be to define a 2D revolution data set and then add a slice plot in the 3D-Plot group. You can also try to use extrusion coupling operators.
Best regards
Bettina Schieche
Hi, one idea could be to define a 2D revolution data set and then add a slice plot in the 3D-Plot group. You can also try to use extrusion coupling operators. Best regards Bettina Schieche
