Error: Failed to find a solution. Divergence of the linear iterations. Returned solution is not converged.
Hi all,
i'm a new user of comsol
I'm trying to simulate a bonding wire inductor, but no way to make it converge.
cannot use 2D axysimmetric due to the shape of the inductor.
Tried all possible solutions:
1) direct solver: not enough memory
2) raised number of iterations
3) changed tolerance
4) changed mesh
The convergence plot stops at about 8th iteration and says
I use only MF module
In DC (stationary) it works well. But this message pops up when i go in AC, even at extremely low frequencies.
Any idea?
Thank you in advance :-)
Antonio
1 Reply Last Post 14 févr. 2014, 19:44 UTC+1
Hello Antonio Camarda
Posted: 1 decade ago 14 févr. 2014, 19:44 UTC+1
I got the same problem Did you find the solution. Please let me know. Thanks
Hi all,
4) changed mesh
Any idea?
Antonio
Hi I got the same problem Did you find the solution. Please let me know. Thanks [QUOTE] Hi all, i'm a new user of comsol I'm trying to simulate a bonding wire inductor, but no way to make it converge. cannot use 2D axysimmetric due to the shape of the inductor. Tried all possible solutions: 1) direct solver: not enough memory 2) raised number of iterations 3) changed tolerance 4) changed mesh The convergence plot stops at about 8th iteration and says Error: Failed to find a solution. Divergence of the linear iterations. Returned solution is not converged. I use only MF module In DC (stationary) it works well. But this message pops up when i go in AC, even at extremely low frequencies. Any idea? Thank you in advance :-) Antonio [/QUOTE]
