2D Depth in 4.3a
Posted 10 nov. 2013, 23:12 UTC+1 Heat Transfer & Phase Change, Geometry Version 4.3a 1 Reply
I am relatively new to COMSOL. I am using version 4.3a. My issue is with heat transfer in solids, specifically the depth to my geometry. It is my understanding that the default depth is 1m. Since my model's scale is much smaller than this, mm, it throws off all off the calculations.
My question is how do I change the default depth to a specified depth. Should I simply make a 3d model instead? I was hoping to compare both 2d and 3d computations.
Thank you for any advice/help
Hello Kegan Dellinger
