coupling two-phase laminar and turbulent model
I'm new to COMSOL and I would like to build a model for my experiment. Based on the simulation result, I believe I need to use two phase laminar model to run the simulation in the beginning and let turbulent model to take over the rest of simulation after a certain time point. If you have any suggestions for me, it would be greatly appreciated. Thank you.
Kevin
2 Replies Last Post 21 nov. 2013, 00:28 UTC+1
Alberto Garcia-Cristobal
Posted: 1 decade ago 19 nov. 2013, 11:28 UTC+1
HI
I think what u have to do is to create two studies
1st- Phase-1
2nd Phase-2
Then u need to couple them. The coupling procedure is discussed in the link below. The procedure is general so that u can apply it to ur cases
www.comsol.com/community/forums/general/thread/40597/
HI I think what u have to do is to create two studies 1st- Phase-1 2nd Phase-2 Then u need to couple them. The coupling procedure is discussed in the link below. The procedure is general so that u can apply it to ur cases http://www.comsol.com/community/forums/general/thread/40597/
Posted: 1 decade ago 21 nov. 2013, 00:28 UTC+1
HI
1st- Phase-1
2nd Phase-2
Thank you for your reply. I would try it later this week and reply in this thread. :)
[QUOTE] HI I think what u have to do is to create two studies 1st- Phase-1 2nd Phase-2 Then u need to couple them. The coupling procedure is discussed in the link below. The procedure is general so that u can apply it to ur cases http://www.comsol.com/community/forums/general/thread/40597/ [/QUOTE] Thank you for your reply. I would try it later this week and reply in this thread. :)
