Simulating a MOSFET with silicon nitride as gate dielectric, using semiconductor module
Undefined value found.
- Detail: Undefined value found in the equation residual vector.
There are 24 degrees of freedom giving NaN/Inf in the vector for the variable mod1.N.
at coordinates: (5.84978e-005,-3.33333e-009), (5.84931e-005,-6.66667e-009), (5.12993e-005,-6.66667e-009), (5.13039e-005,-3.33333e-009), (5.03756e-005,-6.66667e-009), ...
There are 24 degrees of freedom giving NaN/Inf in the vector for the variable mod1.P.
There are 24 degrees of freedom giving NaN/Inf in the vector for the variable mod1.V.
While trying to simulate a MOSFET with silicon nitride as the gate dielectric layer, I am getting this error message.
What is the problem here and how to solve it?
5 Replies Last Post 30 déc. 2016, 03:50 UTC+1
Hello Soumendu
Posted: 1 decade ago 7 juil. 2014, 12:30 UTC+2
Hey Soumendu,
I am getting a similar error. Did you come up with solution. I am trying to use SiO2 as insulator but it shows a red cross on Materials and SiO2 in the model builder. While using semiconductor module can we use material other than given in semiconductor material like SiO2 or any metal.
-Anup Kumar
Hey Soumendu, I am getting a similar error. Did you come up with solution. I am trying to use SiO2 as insulator but it shows a red cross on Materials and SiO2 in the model builder. While using semiconductor module can we use material other than given in semiconductor material like SiO2 or any metal. Thanks -Anup Kumar
Posted: 1 decade ago 15 août 2014, 11:30 UTC+2
Hi, Soumendu
Check mesh in your model (is it too fine?) or maybe this problem is due to missing boundary condition.
Hi, Soumendu Check mesh in your model (is it too fine?) or maybe this problem is due to missing boundary condition.
Posted: 1 decade ago 15 août 2014, 12:02 UTC+2
Hi, Anup
If you add Charge Conservation node related to SiO2 domain, red cross will disappear.
In my opinion, when you use Semiconductor Module, COMSOL think that all domains are semiconductors by definition and for this reason COMSOL ask you to define all parameters required by physics (band gap, electron affinity etc.). But you can include insulator in the model by using Charge Conservation feature. As a result you need to specify only relative permittivity to describe SiO2 (actually relative permittivity or polarization or remanent electric displacement - it's your choice in Charge Conservation settings window -> Electric Field)
Hope this helps!
Hi, Anup If you add Charge Conservation node related to SiO2 domain, red cross will disappear. In my opinion, when you use Semiconductor Module, COMSOL think that all domains are semiconductors by definition and for this reason COMSOL ask you to define all parameters required by physics (band gap, electron affinity etc.). But you can include insulator in the model by using Charge Conservation feature. As a result you need to specify only relative permittivity to describe SiO2 (actually relative permittivity or polarization or remanent electric displacement - it's your choice in Charge Conservation settings window -> Electric Field) Hope this helps!
Posted: 9 years ago 21 févr. 2016, 14:27 UTC+1
I'm trying to simulate MOSFET using explicit SiO2 as gate oxide instead of using thin insulator gate. Although applying charge conservation to SiO2 layer only require dielectric constant of SiO2 to define, but it is not allowing me to use metal contact or terminal on the top surface of SiO2 layer. Also, if I use an extra gate material, it requires all semiconductor parameters, which are not available for metals. So is there any other physics or boundary or domain condition I have to use to simulate?
Please look into it and any suggestion will be highly appreciable.
Thank you,
I'm trying to simulate MOSFET using explicit SiO2 as gate oxide instead of using thin insulator gate. Although applying charge conservation to SiO2 layer only require dielectric constant of SiO2 to define, but it is not allowing me to use metal contact or terminal on the top surface of SiO2 layer. Also, if I use an extra gate material, it requires all semiconductor parameters, which are not available for metals. So is there any other physics or boundary or domain condition I have to use to simulate? Please look into it and any suggestion will be highly appreciable. Thank you,
Posted: 9 years ago 30 déc. 2016, 03:50 UTC+1
I'm facing a same problem of metal layers simulation in Semiconductor module.
Have you able to solve it?
Hi, I'm facing a same problem of metal layers simulation in Semiconductor module. Have you able to solve it?
