defining temperature of inlet fluid?
How do I inject a fluid with a required temperature through an inlet?
Obviously it's temperature needs to be different from the initial fluid in the model .
thanks
Dave
3 Replies Last Post 27 janv. 2014, 10:20 UTC+1
Posted: 1 decade ago 17 janv. 2014, 18:13 UTC+1
rightclick at the heat transfermodule and add "+Temperature" choose your bondary and set a temperature
Posted: 1 decade ago 17 janv. 2014, 22:06 UTC+1
OK I found that it works using the Conjugate Heat Transfer module, see Heat Sink model example.
In this model fluid (laminar flow) is introduced through the inlet at a predefined temperature.
I tried doing this with the multiphysics heat transfer module +laminar flow without success.
Can someone confirm that is only possible with Conjugate Heat Transfer ?
David
Hi OK I found that it works using the Conjugate Heat Transfer module, see Heat Sink model example. In this model fluid (laminar flow) is introduced through the inlet at a predefined temperature. I tried doing this with the multiphysics heat transfer module +laminar flow without success. Can someone confirm that is only possible with Conjugate Heat Transfer ? Thanks David
Posted: 1 decade ago 27 janv. 2014, 10:20 UTC+1
Hi David,
your problem is very strange.
You need only to define a boundary condition for the temperature. It should be possible in all the heat transfer modules.
try to post your file, I will check!
Marino Miccio
Chemical Engineer
marinomiccio.wix.com/home
Hi David, your problem is very strange. You need only to define a boundary condition for the temperature. It should be possible in all the heat transfer modules. try to post your file, I will check! -- Marino Miccio Chemical Engineer http://marinomiccio.wix.com/home
