Daniel Smith
COMSOL Employee
10 févr. 2014, 09:05 UTC−5
Hi Arno, you can add an "Auxiliary Dependent Variable" to your model for the charge. In the "Wall" condition you can use the option "Assign new value to auxiliary variable" which allows you to change its value when the particle hits the wall (see attached V4.3b model).
This requires V4.3b or later.
Dan
Dan
10 févr. 2014, 09:35 UTC−5
Thank you very much!
Best regards
Best regards
9 years ago
17 nov. 2016, 13:24 UTC−5
Dan
Dear Dan,
Is it possible to couple the flow field with the particle tracing? I want to simulate the particle deposition on a wall, and is it also possible to let the uncharged particles to deposit on a wall?
If I use the charged particle tracing module, then how to couple it with the flow field?
Thank you in advance.
Best Regards,
Bill
[QUOTE]
Dan
[/QUOTE]
Dear Dan,
Best Regards,
Bill
