Filtration of nanoparticles in porous membrane
Hi all, I'm simulating the rejection of nanoparticles that pass through a porous membrane.
I am using the physics of "Particle tracing for fluid flow" and "Laminar flow" and set up some particles bigger than the pore size so that those particles are supposed to be rejected (not pass through the membrane).
I expected those big particles would remain on the membrane surface, not passing though membrane.
But I found that all of them pass through the membrane when I check the statuses of their final deposition.
Do I have to use another module to simulate the particle filtration though a porous membrane or is there some thing that I may miss?
Thank you for your reply!
Dukwoo
4 Replies Last Post 1 oct. 2014, 01:42 UTC+2
Posted: 1 decade ago 18 févr. 2014, 10:58 UTC+1
Hi Dukwoo,
which is your domain? Have you designed a porous membrane with nano pores?
If yes have you used a mesh with elements of the right size?
Regards
Marino Miccio
Chemical Engineer
marinomiccio.wix.com/home
Hi Dukwoo, which is your domain? Have you designed a porous membrane with nano pores? If yes have you used a mesh with elements of the right size? Regards -- Marino Miccio Chemical Engineer http://marinomiccio.wix.com/home
Posted: 1 decade ago 18 févr. 2014, 17:07 UTC+1
Yes, the pore size of my membrane is ~15 nm of diameter.
Technically, I didn't use user-defined meshing but physics-controlled meshing (as "Finer").
Should I define the mesh myself?
Thank you!
Dukwoo
Yes, the pore size of my membrane is ~15 nm of diameter. Technically, I didn't use user-defined meshing but physics-controlled meshing (as "Finer"). Should I define the mesh myself? Thank you! Dukwoo
Posted: 1 decade ago 19 févr. 2014, 10:23 UTC+1
You should check also graphically if your mesh elements are smaller than your pores.
If it is not, you can try to solve it with an user defined mesh.
Marino Miccio
Chemical Engineer
You should check also graphically if your mesh elements are smaller than your pores. If it is not, you can try to solve it with an user defined mesh. -- Marino Miccio Chemical Engineer http://marinomiccio.wix.com/home
Posted: 1 decade ago 1 oct. 2014, 01:42 UTC+2
hello there,
did you find a solution to your problem. I ran into the same truing to simulate transport of nanoparticles through a microfilter pore. particles larger than the filter pore passed through it..
satish
hello there, did you find a solution to your problem. I ran into the same truing to simulate transport of nanoparticles through a microfilter pore. particles larger than the filter pore passed through it.. satish
