help needed: magnetic force calculation
Posted 25 févr. 2014, 12:46 UTC+1 Low-Frequency Electromagnetics, Results & Visualization Version 4.4 5 Replies
I tried to use COMSOL 4.4 to model the magnetic field surrounding a permanent magnet and calculate the force acting on an object nearby. ( in 3D case )
The geometry is simple, a block ( the "object" ) is placed next to a block-shaped permanent magnet. I used mfnc, and the magnet is defined by a "remanent flux density" constitutve relation. The force acting on the "object" is calculated by adding a "force calculation".
The results of magnetic field is reasonable, but then I came up with a problem about the magnetic force.
I assigned the material "air" (with mur = 1) to all the domains, so theoretically the force acting on the "object" has to be ZERO. But the results gives a force of ~30 N.
I've read some of the posts about "force calculation" and " Maxwell stress tensor", but still cannot fix the problem.
Really appreciate it if anyone can help me on this.
5 Replies Last Post 25 févr. 2014, 17:22 UTC+1
