Spiral Coil
I am trying to simulate a spiral flat coil. The input is the current I define while I would like to see the magnetic flux density generated. I made three models in the same way, but the dimensions of the coil are different.
Two of the simulations run perfectly, while the other one gives me INVERTED MESH ELEMENT warning when I use coarse mesh and DIVERGENCE error when I use fine mesh.
Could you please help me to understand why 2 of the simulations run while the other one gives me errors?
Nima.
1 Reply Last Post 11 mars 2014, 09:34 UTC+1
Posted: 1 decade ago 11 mars 2014, 09:34 UTC+1
same problem Nima !
i will contact u as i figure out
good luck
same problem Nima ! i will contact u as i figure out good luck
