Lumped Port S-parameters > 1 w/circuit interface @ port
Posted 3 mars 2014, 14:00 UTC−5 Low-Frequency Electromagnetics, RF & Microwave Engineering, Results & Visualization 3 Replies
Good day,
This is a problem I have been dealing with for a while.
I have a fairly basic setup involving 2 coupled antenna. I have extracted my desired S-parameters from my system in question, and have determined optimal impedance values that should be presented at the ports to optimize S21. Now, I want to simulate my coupled antennae, as I expect the field distribution to change under optimal loading (it does).
The problem arises after simulating the coupled and optimally matched system. Now, my extracted S-parameters are > 1 (in all regards, sometimes abs() >1, sometimes real()>1, also imag()>1). I believe this might just be an artifact of the means by which S11 is calculated for a Lumped Port (S11 = (Vport - Vin) / Vport) when a negative/imaginary value is passed by Vin. (Vin is what is presented to the port, Vport is the calculated by line integral value).
Thus far, I can produce unrealistic S-parameters by either (1) presenting a lumped port with Zo = optimal impedance (though, I kind of expect this to produce odd results; now the characteristic impedance of the line is imaginary) or by (2) using a circuit at the input, with appropriate LC matching networks in place.
If anyone has any insight/tricks to get COMSOL to present me with accurate S-parameters, I would appreciate it. Otherwise, I can always use the un-matched ones and fix them in post.
Thank you,
Jason
Thank you,
Jason
3 Replies Last Post 18 nov. 2016, 11:34 UTC−5
