Difference solutions between importing wavelength and frequency
Posted 25 mars 2014, 04:46 UTC+1 RF & Microwave Engineering Version 3.5a 0 Replies
I study on the model of step-index-fiber, the solution is for importing the wavelength of 1.55 um. When I change the parameter to corresponding frequency( Specify wave using has already changed ), effective mode index is different from that of importing wavelength. It is supposed to be the same. I am confused for the two different solutions. Which one is the correct solution?
Thank you for reply at first.
Huang Lili
Hello 莉莉 黄
