How to make EM wave induced currents as a input in Magetic Field module
Posted 1 avr. 2014, 04:29 UTC−4 Low-Frequency Electromagnetics, RF & Microwave Engineering Version 4.3, Version 4.4 0 Replies
I want to create a model that a plane EM wave incident to two metallic coils, then there are in phase induced currents in two coils, and there must be the EM force between the two coils. I want to create a 1D graph with incident wave frenquency as x-axis and EM force as y-axis.
I first create a model including EM Wave Module, and then derive the current density of coils. I also know Magnetic Field Module can calculate EM force. The question is how can I put my current result from the EM Wave Module into the Magetic Field module>single turn coil>gap feed>coil current . I create a variable Ia, which's expression is IntegrateOverA(emw.normJ), as a input of coil current. But it seems that Ia is not only including current data but also including frequency data, and it just cannot work. So what I need to do to create a right model.
Hello Tenglong Wanghuang
