moving heater
I am trying to model heat transfer to a fluid flowing in a rectangular duct. The duct is heated at the bottom wall through a rectangle step function such that only a short length of the wall is heated. I am trying to make this step pulse move with time, i.e a different section is heated at each instant. When I specify the step function limits in terms of 't' I get an 'unknown variable' error. Is there a way to do this in Comsol?
Thanks.
2 Replies Last Post 28 déc. 2015, 14:50 UTC+1
Hello Kumar
Posted: 10 years ago 26 déc. 2015, 10:33 UTC+1
Did you got your model working? Could you share it with me how you did it?
Thank you so much in advance.
BR
Valente Martins
Hello, Did you got your model working? Could you share it with me how you did it? Thank you so much in advance. BR Valente Martins
Posted: 10 years ago 28 déc. 2015, 14:50 UTC+1
Dear Valente,
Check out COMSOL Application Gallery example #20401 for how to model a traveling load: www.comsol.com/model/traveling-load-20401
Nagi Elabbasi
Veryst Engineering
Dear Valente, Check out COMSOL Application Gallery example #20401 for how to model a traveling load: http://www.comsol.com/model/traveling-load-20401 Nagi Elabbasi Veryst Engineering
