2 decades ago
16 avr. 2010, 12:47 UTC+2
Look at the solvermanager. All variables, which have to be solved, are listed there. Just include them for the solving-process in one step of the segregated solver by opening a new step.
The problem is: Comsol can't solve contact problems time-dependent! You have to change certain settings in the model in order to use time-dependent solving. There is an example-model, you can find somewhere in the discussion forum.
23 mars 2011, 04:55 UTC+1
Hello!
I have the same problem, too. I don't know that if you had solved the problem, could you give me same advice about the error?
My model is also coupled structual and thermal multiphysics with friction, when I use stationary slover ,the nonlinear solver has no convergence. So i tried the time-dependent solver algorithm, it occurs error 7220.
In the HELP file, it says: the solve contact problems,use the augmented Lagrangian method. I think the augmented Lagrangian method is Stationary solver, what I should do with the time-dependent solver?
Thank you in advance!
Yajuan
Hello!
Yajuan
23 mars 2011, 05:02 UTC+1
Hello!
I had the problem,too.
Does "Comsol can't solve contact problems time-dependent! " mean that there is no time-dependent solver for contact problem , if we try to solve the problem ,we should use the script?
About "You have to change certain settings in the model in order to use time-dependent solving." Could you please give me more details about "change certain setting"?
Yajuan
Hello!
Yajuan
9 avr. 2011, 15:12 UTC+2
Hi everybody,
I have the same problem to, please, if someone could send a model or explain clearly the steps to make the contact problem work in time-dependent I'd be very grateful.
Thanks.
Hi everybody,
Thanks.
9 avr. 2011, 18:00 UTC+2
why do you need the time dependence ? to see the bouncing around of the contact ?
or is it just that you want a load that is increasing with time ?
If so use a stationary with a parameter called "t" and it's done
my model is a 4.1 (sorry I have left 3.5 behind ;)
