Smoke extraction from a building
Hello comunity!!
I'm in a trial version of COMSOL to evaluate its acquisition.
I want to simulate the smoke extraction from the building when there is a fire.
I plan to start by simulating a room where there is a source of heat and smoke and also a flow output with constant flow.
So far I have modeled the room and the flow output but I can't find a source that will give me heat and smoke (like a gas).
In the end I want to make a transient analysis and check that smoke isn't concentrated at dangerous levels below certain height and I also want to check temperatures around the smoke generation area.
Any help with the modelling of the smoke generation will be much appreciated.
Kind regards.
Eloy Ruiz
Lima, Peru
1 Reply Last Post 7 juil. 2014, 11:59 UTC+2
Posted: 1 decade ago 7 juil. 2014, 11:59 UTC+2
I think you should work with 'conjugated heat transfer' physics for the flow of air/gas and heat distribution, and 'transport of concentrated species' to find the gas distribution. I think you have to put an inflow heat flux in the heat transfer physics and an inflow in the species physics. But I am not entirely sure if this has the right effects.
