Edgar J. Kaiser
Certified Consultant
7 juil. 2014, 19:47 UTC+2
Hi Derek,
COMSOL is based on finite elements, nothing else.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Derek,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
Jeff Hiller
COMSOL Employee
15 juil. 2014, 15:03 UTC+2
COMSOL uses finite elements primarily but not exclusively.
Per
www.comsol.com/comsol-multiphysics , "Several different methods are used in the add-on modules, including finite element analysis, the finite volume method, the boundary element method, and particle tracing methods, but the emphasis of COMSOL Multiphysics is on the finite element method."
Per http://www.comsol.com/comsol-multiphysics , "Several different methods are used in the add-on modules, including finite element analysis, the finite volume method, the boundary element method, and particle tracing methods, but the emphasis of COMSOL Multiphysics is on the finite element method."
Edgar J. Kaiser
15 juil. 2014, 15:29 UTC+2
Hi Jeff,
interesting, I haven't come across that. So coming back to the original poster's question: is it somewhere visible, which method is used in which application case? Is the documentation providing this information?
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Jeff,
Edgar
Edgar J. Kaiser
Jeff Hiller
COMSOL Employee
15 juil. 2014, 16:12 UTC+2
Yes, it does. For instance, the Semiconductor Module offers both finite element and finite volume discretizations, and you will find this documented in that module's User's Guide, version 4.4, on page 22 and following, along with a discussion of when to use one formulation versus the other and how to see which is used inside the GUI under the Discretization tab.
